twardy dysk do PC10-III poszukuję
Artur23
#1 Postautor: Artur23 » czw mar 01, 2018 3:58 pm
Witam
Zakupiłem Commodore PC10-III .komputer nie posiada dysku twardego. Orientuje się ktoś jaki był montowany fabrycznie dysk (model , nazwa itp).
Dzięki i pozdrawiam
rs2322
Re: twardy dysk do PC10-III poszukuję
#2 Postautor: rs2322 » sob mar 03, 2018 9:52 am
Hard Drive: 20MB XTA (8-bit IDE) (standard on PC20-III)
Hard Drives
The PC20-III comes standard with a 20MB Western Digital XTA (8-bit IDE) hard drive pre-installed while the PC10-III and Colt have only floppy drives standard. When no hard drive is installed, even if the on-board interface has been disabled via JMP208, the BIOS will display "Hard disk not found" on startup.
It is possible to add a hard drive to the PC10-III and Colt or to replace the hard drive in the PC20-III. There are two ways to add or replace a hard drive in these systems. You can either use the built-in XTA interface or use an add-in controller card. Using the on-board interface frees an ISA slot for additional expansion. Using an add-on card allows for significantly more models of hard drive to be used, and even multiple drives.
zrodlo: http://www.vcfed.org/forum/showthread.p ... e-PC10-III
