Sprzedam Cynthcart v1.2.4 SID Music Maker do 64/128
szu
#1 Post autor: szu »
Chcial by ktos kupic ten Cynthcart? Mam pare
Kto jest zainteresowany, wyslij mi wiadomosc.
Versja 1.2.4
* 3 Note Polyphony
* Works with the common C64 piano keyboard overlay
* No latency
* Adjustable vibrato
* Portamento effect (sliding notes)
* Can change patches and settings while playing
* Support for 2nd SID chip (stereo chorus effects)
* Filter, pulse width, vibrato, and pitch via paddle controllers
* Whammy (space) bar
* Control of attack, release, and many other sound parameters
* Tuning adjustment
* Psychedelic rave color patterns
* On-screen help
* SID hex editor for advanced users
* Can turn off video chip to reduce noise
* PAL and NTSC tuning tables with automatic selection
* Designed to be used easily without a TV/monitor
* Copies itself to RAM (cartridge can be removed after loading)
